So I am trying to run MW2 in a virtual machine using Windows 98Se. The game installs off the disks just fine, everything seems to work till I try to launch. I will see a brief flash of the load screen, then the display goes blank black, no sound or anything. CTRL-ALT-DEL doesn't exit out either, I usually have to force a restart. I'm sure some kind of patch or update should fix this, anyone here know what might be causing this? I have not tried Mercs yet, I suspect it will act the same.
I wanted to run in Windows 95 (yes I have a copy of that), but the emulated sound card is not properly supported by 95, so I get no sound, and I do get a crash on launch. In 95 it is a proper crash, with a bunch of technical mumbo-jumbo.
I am focusing on running this in '98 for now, unless someone here has a better solution. I could not get the game to run through MechVM on Windows XP or 7. Running in Dosbox through MechVM doesn't work either, I just get a garbled display.
Running MW2 on Windows 98, problems
Khan Tyranitar
Khan Tyranitar
Re: Running MW2 on Windows 98, problems
Seriously, no one has had problems running on Windows 98?
It's difficult to check if you don't even mention which edition you are trying to use.
- Hadakajime
- House Steiner Private
sounds like a version compatibility problem with how you've setup the virtual machine...?
check what version you have and look it up in this guide:
viewtopic.php?f=9&t=281
