In the past I havent been soo picky about mechs, but now I am. I want the best builds you can make, but they have to align to certain specifications/purposes.
*NOTE* : You can submit C number! They wont have the same rules applied. For those; all I ask is that you provide the highest quality ones possible for the job.
Send mech files or zip files to:
netmech.revival@gmail.com
Specifications:
IMPORTANT: YOUR SUBMITTED MECHS MUST BE NAMED "RAIDER" , "DEFENDER" or "ASSAULT" ONLY
Raider class
- No missle Racks
- Balanced armour with rear bias*
- Can offset armour from arms
- Minimum 4 jumpjets
Defender class
- Up to 6 missle racks
- Weak rear armour
- Can't offset armour from arms + legs
- Maximum 2 jumpjets
Assault class
- Up to 2 missle racks
- Balanced armour with front bias*
- Can offset armour from arms + legs
- Minimum 2 jumpjets
* Armour bias means that the mech must have atleast 60% of armour allocated to that section
I will only be accepting one of each class for every mech, which will be decided upon inspection and approval.
Thank you. Any help is very much appreciated.
