Because I wasn't the only person wondering how to do this:
When you're mounting the directory where you plan to install Mercs, add "-freesize 1536mb" to the end of the MOUNT command. (It doesn't have to be 1536. Anything in the neighborhood of mid 90s hard drive sizes, but more than ~160 and less than ~2000 should work.)
On an unrelated note, it seems like Assasin's weight is a bit buggy. Ditto the salvaged Jenner from the Galedon V campaign. (Especially the armor on the rear R/L torso)
How to do a full install in dosbox
UmbralRaptor
