I know you guys are probably sick of all these issues but i have been cruising the internet for days trying to get this game to work. So this is what i have done:
-I run Windows xp pro sp3 and i have not tried to run this on a VM of DOS or 95
-The version of the game is win95 ( at least is says DOS and WIN95 compatible on the disc..i lost the cover forever ago)
-My current method is Slugs Hook...and i have followed the setup for it on this website and at Chris's site as well. I can go step by step if anyone needs me to on what i did
-I was actually successful. It launched.. i created a new campaign and played through about 3-4 missions. then when i was about to blow up a rebel DC Assassin mech... it froze, screen flashed and this error message came up..
"The instruction at "0x2000b95d" referanced memory at "0x02600998". The memory could not be "read"
I cannot find anything for this problem >.<
memory issue with MW2: Mercenaries
Re: memory issue with MW2: Mercenaries
Sorry, we don't have the game's source code, so I cannot help you with or even fix this specific issue for you. You're lucky the Win95 version is running, it doesn't always. The game may crash occasionally, so keep saving before and after missions.
If there is a DOS version on the CD, it is usually more stable.
Ah ok thanks anyways. It doesnt allow me to play at all.. every time a start to log into a saved game or create a new one it says that >.<. Think the best way is to try DOS?Skyfaller wrote:Sorry, we don't have the game's source code, so I cannot help you with or even fix this specific issue for you. You're lucky the Win95 version is running, it doesn't always. The game may crash occasionally, so keep saving before and after missions.
Yes, DOS is the best way no question
Question then. I tried to set the Compatability to MS-DOS, but it is not listed. The disc itself says it is compatable. Options in the drop dpwn box are win95, win98, win2000, win nt4.0Sir MMPD Radick wrote:Yes, DOS is the best way no question
Okay just editing this... I think i just installed the Mech VM and it read the DOS version. il update this too. Am i doing this correctly?
Tried the DOS version off the VM...keeps saying Process ending in 0
Tried the Win95 version off the VM...kept skipping
edit* ok tried the DOS version and this time i started up DOS BOX. Bingo!
Now I am just looking how to enable Audio and find my saved games so i can edit them^^
to fix the sound in dosbox go for the setsound.bat file in the mech2 directory.
The pilots save files are inside of mw2reg.cfg or something close to that if my memory serves me right. (sorry i have not looked in the dir to verify if it wrong i will)
