Dosbox recording issue. *Resolved!*
Re: Dosbox recording issue. *Resolved!*
Also the codecs must be the same
I'm guessing they are, since all I want to do is combine the mw2shell file with the mw2 file. They're two different executables, so they create different files while recording. So yeah I don't know what my next step should be. If you can, it would be a great help if you could do that remote assistance thing to show me exactly what I need to do, because I have a feeling I either missed something or did it the wrong way. Once I see how it's done, then I should be able to do it from there on.
I cannot do that anymore... the beta expired sorry
The only way I can is if you use UltraVNC server and forward the ports then pm the password etc.
Yeah I can probably do that. What do I need to do and where do I need to go?
