Mech2 Track IR Support
wolfcub
Post by wolfcub »
I have succeed in getting Track IR Motion capture to work with Mech2!!!
http://www.naturalpoint.com/trackir/ Camera & Clip you use to capture motion of your head, and translate it to ingame movement.
Using a program http://kaf.tri6.net/trackmapper/ Trackmapper, it simulates keyboard keys from the direction you move your head.
I got this to work in Mech2, for the cockpit glancing. I will put up a video later showing this ingame and me using it. :o
But this is an extremely cool thing, I can pilot my mech and look without having to actually move my torso and look around the cockpit with ease.
If anyone else wants to use this too, I have attached the Trackmapper config file for those that want it.
Mech2.rar
Trackmaster Mech2 Config
(182 Bytes) Downloaded 416 times
The custom mech2 controls required to be set are
Glance Left: [ Glance Right: ] Glance Up: G Glance Down: H
PEN-Stealth
Re: Mech2 Track IR Support
Post by PEN-Stealth »
awesome, works great, thanks!
so what do you need to do this?
a wii?
Nice, wolfcub. There was some old early "VR" headset that worked with MW2, too, but TrackIR is a lot more modern (and better since you still use your monitor and not little eye screens). So this is sort of like coming full circle, as MW2's "virtual cockpit" was a pretty awesome thing when it first came out.
are yall talking this thing?
cause i would rather just get the wii controler and bar, and then do the "neurohelm" aka a hat
http://www.youtube.com/watch?v=Jd3-eiid-Uw good vid to show how/what head tracking looks like
alot cheaper, and you really could make a neurohelm:) especially if you got a pair of those glasses, that put little 2in screens in front of your eyes, so it looks like you are looking at a 10ft screen
wolfcub
Post by wolfcub »
If you like screwing with things alot, then do a wii, but this is ALOT simpler and honestly, just a hundred bucks, and REALLY efficient. In my opinion, much better then playing a wii in terms of movements.
Cyril wrote:cause i would rather just get the wii controler and bar, and then do the "neurohelm" aka a hat
wolfcub wrote:If you like screwing with things alot, then do a wii
On this note, can get a Wiimote to work on your computer if you have Bluetooth and this freeware program called "Glovepie"...
