Default Key Map
Collection of useful posts.
Locked
Default Key Map
Anyone got a list of all the default keys are?
Re: Default Key Map
#*  MechWarrior II Keyboard Mapping File
#*  MODIFY THIS FILE AT YOUR OWN RISK.
###### AI Commands #########
MAIN_MENU                       Esc
USER_MENU                       u
STARMATE_MENU                   b
STARMATE_MENU                   CTRL+F1
STARMATE_ONE_MENU               CTRL+F2
STARMATE_TWO_MENU               CTRL+F3
STARMATE_THREE_MENU             CTRL+F4
STARMATE_FOUR_MENU              CTRL+F5
STARMATE_FIVE_MENU              CTRL+F6
STARMATE_SIX_MENU               CTRL+F7
STARMATE_SEVEN_MENU             CTRL+F8
###### F-Key Displays #######
MFD_CYCLE                       F1
NEXT_RADAR_MODE                 F2
RADAR_MAP_TOGGLE                F3
TOGGLE_TARGET_DISPLAY           F4
TOGGLE_DAMAGE_DISPLAY           F5
TOGGLE_HTAL                     F6
TOGGLE_REAR_VIEW                F7
TOGGLE_DOWN_VIEW                F8
TOGGLE_WEAPON_DISPLAY           F9
ORDINANCE_VIEW                  F10
TOGGLE_HUD                      F11
DISPLAY_OBJECTIVES              F12
COCKPIT_VIEW                    c
COCKPIT_RESET_ZOOM              CTRL+z
####### Driving Your Mech ########
RESET_INPUTS	                /
FEET_TO_TORSO                   m
THROTTLE_STOP                   1
THROTTLE_2                      2
THROTTLE_3                      3
THROTTLE_4                      4
THROTTLE_5                      5
THROTTLE_6                      6
THROTTLE_7                      7
THROTTLE_8                      8
THROTTLE_9                      9
THROTTLE_FULL                   0
REVERSE_DIRECTION               `
REVERSE_DIRECTION               BSP
###### Targeting ##########
NEXT_TARGET                     t
PREV_TARGET                     r
RESET_TARGETTING		CTRL+t
TARGET_NEAREST_ENEMY            e
TARGET_FRIENDLY			f
TARGET_AT_RETICLE               q
INSPECT_TARGET                  i
NEXT_NAVPOINT                   n
PREV_NAVPOINT                   SHIFT+n
RADAR_ZOOM_IN                   x
RADAR_ZOOM_OUT                  SHIFT+x
EJECT                           CTRL+ALT+e
TOGGLE_AUTOEJECT                CTRL+e
STARTUP_MECH                    CTRL+s
SHUTDOWN_MECH                   s
OVERRIDE_SHUTDOWN               o
TOGGLE_AUTOPILOT                a
TOGGLE_MASC                     v
INFRARED                        l
ENHANCED_VISION			w
SELF_DESTRUCT                   Ctrl+Alt+x
############ Weapons ####################################
ADD_WEAPON_TO_GROUP_1           SHIFT+1
ADD_WEAPON_TO_GROUP_2           SHIFT+2
ADD_WEAPON_TO_GROUP_3           SHIFT+3
TOGGLE_GROUP_FIRE               \
NEXT_WEAPON_GROUP               '
FIRE_WEAPON_GROUP               ;
JETTISON_AMMO                   k
############# Miscellaneuos ###########################
CRACK_MODE                      CTRL+ALT+f
DUMP_GIF                        Ctrl+p
PAUSE_GAME                      Alt+p
PAUSE_GAME                      PAUSE
#                           MechWarrior II                                #
#                         Input Mapping File                              #
#  This file allows you to configure the inputs to the MechWarrior sim.   #
# Available controls
# torso_tilt
# torso_tilt_plus
# torso_tilt_minus
# torso_tilt_reset
# torso_pan
# torso_pan_plus
# torso_pan_minus
# torso_pan_set
# torso_pan_reset
# throttle
# legs_pan_delta
# jumpjet_enabled
# jumpjet_fire_left
# jumpjet_fire_right
# jumpjet_fire_forward
# jumpjet_fire_backward
# throttle_plus
# throttle_minus
# throttle_set
# weapon_fire
# weapon_cycle
# weapon_fire_group
# weapon_fire_group_1
# weapon_fire_group_2
# weapon_fire_group_3
# weapon_cycle_group
# toggle_group_fire
# legs_pan_minus
# legs_pan_plus
# advance_nav
# previous_nav
# reset_nav
# advance_target
# previous_target
# reset_target
# target_reticle
# target_friendly
# nearest_enemy
# target_last_shot
# inspect_target
# advance_gamepiece
# previous_gamepiece
# reset_gamepiece
# advance_gamething
# previous_gamething
# reset_gamething
# self_destruct
# autopilot
# pilot_tilt
# pilot_tilt_plus
# pilot_tilt_minus
# pilot_tilt_reset
# pilot_pan
# pilot_pan_plus
# pilot_pan_minus
# pilot_pan_reset
# glance_left
# glance_right
# glance_up
# glance_down
# eyepoint_tilt
# eyepoint_tilt_plus
# eyepoint_tilt_minus
# eyepoint_tilt_reset
# eyepoint_pan_delta
# eyepoint_pan_plus
# eyepoint_pan_minus
# eyepoint_pan_reset
# eyepoint_slide_delta
# eyepoint_slide_plus
# eyepoint_slide_minus
# track_distance_delta
# track_distance_plus
# track_distance_minus
# track_height_delta
# track_height_plus
# track_height_minus
# zoom_factor
# zoom_factor_plus
# zoom_factor_minus
# zoom_factor_reset
# menu_item
# menu_item_reset
# menu_value
# menu_value_reset
# menu_enter
# menu_abort
# Mouse controls
weapon_fire {
   + mouse     LeftBtn
target_reticle {
   + mouse     MiddleBtn
weapon_cycle {
   + mouse     RightBtn
torso_tilt {
   - mouse       Up/Down
torso_pan {
   + mouse       Left/Right
# Keyboard layout
# Weapon controls on the standard keyboard
weapon_fire {
	+ keyboard	 Space
weapon_cycle {
	+ keyboard	 Enter
# Weapon controls on the keypad
weapon_fire {
	+ keyboard	 KeypadEnter
	- keyboard	 Insert
weapon_cycle {
	+ keyboard	 Delete
weapon_fire_group_1 {
	+ keyboard	NumLock
	- keyboard	LeftControl  # Just because!
weapon_fire_group_2 {
	+ keyboard	GreySlash
weapon_fire_group_3 {
	+ keyboard	GreyStar
# Throttle control on the top -/+ keys
throttle_plus {
	+ keyboard	 Equal
throttle_minus {
	+ keyboard	 Minus
# Throttle control on the keypad -/+ keys
throttle_plus {
	+ keyboard	 GreyPlus
throttle_minus {
	+ keyboard	 GreyMinus
# Turning, on the keypad arrows
legs_pan_minus {
	+ keyboard	 LeftArrow
	- keyboard	 Insert
legs_pan_plus {
	+ keyboard	 RightArrow
	- keyboard	 Insert
# Turning, on the grey arrows
legs_pan_minus {
	+ keyboard	 GreyLeftArrow
	- keyboard	 Control
legs_pan_plus {
	+ keyboard	 GreyRightArrow
	- keyboard	 Control
# Torso tilting on the keypad arrows
torso_tilt_plus {
	+ keyboard	 UpArrow
	- keyboard	 Insert
torso_tilt_minus {
	+ keyboard	 DownArrow
	- keyboard	 Insert
# Torso tilting on the grey arrows
torso_tilt_plus {
	+ keyboard	 GreyUpArrow
	- keyboard	 Control
torso_tilt_minus {
	+ keyboard	 GreyDownArrow
	- keyboard	 Control
# Torso panning on the ./, (</>) keys
torso_pan_plus {
	+ keyboard	 Period
torso_pan_minus {
	+ keyboard	 Comma
# Torso panning on the keypad End/PgDn keys
torso_pan_plus {
	+ keyboard	 PageDown
	- keyboard	 Insert
	- keyboard	 j
torso_pan_minus {
	+ keyboard	 End
	- keyboard	 Insert
	- keyboard	 j
# Keypad 5 resets torso and pilot head
torso_tilt_reset {
	+ keyboard	 Keypad5
torso_pan_reset {
	+ keyboard	 Keypad5
pilot_tilt_reset {
	+ keyboard	 Keypad5
pilot_pan_reset {
	+ keyboard	 Keypad5
# Pilot head panning on keypad Home/PgUp keys
glance_right {
	+ keyboard	 PageUp
	- keyboard	 Insert
	- keyboard	 j
glance_left {
	+ keyboard	 Home
	- keyboard	 Insert
	- keyboard	 j
# Pilot head tilting/panning on the grey arrow keys (w/ Control)
pilot_tilt_minus {
	+ keyboard	 Control
	- keyboard	 j
pilot_tilt_plus {
	+ keyboard	 Control
	- keyboard	 j
pilot_pan_plus {
	+ keyboard	 Control
	- keyboard	 j
pilot_pan_minus {
	+ keyboard	 Control
	- keyboard	 j
# View zooming on z/Shift-z
zoom_factor_plus {
	+ keyboard	z
	- keyboard	Shift
	- keyboard	Control
zoom_factor_minus {
	+ keyboard	z
	+ keyboard	Shift
	- keyboard	Control
# Jumpjets on the key pad ("j" key required)
jumpjet_enabled {
	+ keyboard	 j
jumpjet_fire_left {
	+ keyboard	 Home
	+ keyboard	 j
	- keyboard	 Insert
jumpjet_fire_right {
	+ keyboard	 PageUp
	+ keyboard	 j
	- keyboard	 Insert
# Jumpjets on the six grey keys ("j" key NOT needed)
jumpjet_fire_forward {
	+ keyboard	 GreyHome
jumpjet_fire_backward {
	+ keyboard	 GreyEnd
jumpjet_fire_left {
	+ keyboard	 GreyInsert
	+ keyboard	 GreyPageUp
legs_pan_minus {
	+ keyboard	 GreyDelete
legs_pan_plus {
	+ keyboard	 GreyPageDown
jumpjet_enabled {
	+ keyboard	 GreyHome
jumpjet_enabled {
	+ keyboard	 GreyEnd
jumpjet_enabled {
jumpjet_enabled {
jumpjet_enabled {
jumpjet_enabled {
# Free eye/track view controls on the keypad (w/ Insert)
eyepoint_pan_minus {
	+ keyboard	 Insert
eyepoint_pan_plus {
	+ keyboard	 Insert
	+ keyboard	 Home
	- keyboard	 Insert
eyepoint_pan_plus {
	+ keyboard	 PageUp
	- keyboard	 Insert
eyepoint_slide_minus {
	+ keyboard	 Delete
	+ keyboard	 Insert
eyepoint_slide_plus {
	+ keyboard	 Insert
eyepoint_tilt_minus {
	+ keyboard	 PageDown
	+ keyboard	 Insert
eyepoint_tilt_plus {
	+ keyboard	 PageUp
	+ keyboard	 Insert
track_distance_minus {
	+ keyboard	 UpArrow
	+ keyboard	 Insert
track_distance_plus {
	+ keyboard	 Insert
track_height_minus {
	+ keyboard	 End
	+ keyboard	 Insert
track_height_plus {
	+ keyboard	 Home
	+ keyboard	 Insert
	+ keyboard	 z
	- keyboard	 Shift
	+ keyboard	 z
	+ keyboard	 Shift
# Free eye/track view controls on the Ctrl-grey arrows
	+ keyboard	 Control
eyepoint_pan_plus {
	+ keyboard	 Control
	+ keyboard	 Control
	+ keyboard	 Control
Re: Default Key Map
Thanks!
Re: Default Key Map
Command menus for up to 7 starmates? My research pointed that you could have up to 4...
That would be so cool, to take charge over an 8-mech star... 8-)
If I can figure out how to add starmates to userstar.bwd using my hex editor...
GungraveDan
Re: Default Key Map
Post by GungraveDan »
LordNova2
Re: Default Key Map
Post by LordNova2 »
This looks like the default controls for Mercs, with Image Enhancement manually added in.
Yea, in the original builds of MW2:31CC and MW2:GBL I belive you had up to three or four star-mates you could drag in. In MW2:Mercs you could have more, or at least in the GAMEKEY.MAP file supported up to seven more lance-mates.
Which game and version did you take these files from Radick?
Re: Default Key Map
Mech2 DOS of course :)
LordNova2
Re: Default Key Map
Post by LordNova2 »
Very interesting.....
I got these versions, according to the INI files from installing the DOS versions in DOSBox:
MW2:31cc DOS (1.6 1995/06/14 12:50:08)
NetMech DOS (1.7 1995/10/27 17:51:47)
MW2:GBL (1.7 1995/10/27 17:51:47)
MW2:Mercs (1.9 1996/04/20 00:15:36)
Which I am guessing is the core simulator versions. And I believe they are the vanilla version of each game, or at least they were the first copies of each game to hit the stores, before they came out with fancy 3DFX editions, ATI Rage editions and BattlePacks ect.
And only Mercs comes up with more than three (two actually since you are point-1) points...
31CC, GBL, and NetMech:
MAIN_MENU                       Esc
USER_MENU                       u
ALL_PT_MENU                     b
ALL_PT_MENU                     CTRL+F1
PT_2_MENU                       CTRL+F2
PT_3_MENU                       CTRL+F3
Mercs:
MAIN_MENU                       Esc
STARMATE_MENU                   b
STARMATE_SET_ALL                ALT+1
STARMATE_SET_PT2                ALT+2
STARMATE_SET_PT3                ALT+3
STARMATE_ATTACK                 ALT+A
STARMATE_DEFEND                 ALT+D
STARMATE_JOIN                   ALT+J
STARMATE_REFORM                 ALT+R
STARMATE_FLEE                   ALT+F
STARMATE_ENGAGE                 ALT+W
STARMATE_SHUTDOWN               ALT+S
AEROTECHSTRIKE                  ALT+X
AEROTECHSTRIKE_JOIN             ALT+C
But this is the GAMEKEY.MAP file which varies from game to game, and version to version of MechWarrior2.
Verry interesting...
ellmo
Re: Default Key Map
Post by ellmo »
Does anybody know how to put spacebar into one of the GAMEKEY.MAP values?
For example, I'm trying:
FEET_TO_TORSO    Space
But no success
Locked
