Keshik Overweight Bug in GBL - solution?
Collection of useful posts.
AFAIK, the hook won't fix the overweight bug in Win95/Battlepack/Titanium Trilogy GBL. However, you can still select any mech you want by hex-editing the MW2PRM.cfg file. For example, simply replace grz00std with grz00usr to use the new config at offset 28h. However, it doesn't always work.
Re: Keshik Overweight Bug in GBL - solution?
Nice find! I will move this thread to the FAQ section.
Editing MW2PRM.cfg has no effect for missions where you may select a new mech, as the shell overwrites any changes to the file. In that case, you still need to replace the mech in the PRJ.
