Inverted Mouse
Collection of useful posts.
Locked
Inverted Mouse
Post by Sir MMPD Radick » Sat Aug 23, 2008 10:29 pm
To change this open input.map and alter this line
torso_tilt {
   - mouse       Up/Down
torso_tilt {
   + mouse       Up/Down
ellmo
Re: Inverted Mouse
Post by ellmo » Thu Dec 23, 2010 6:01 am
Can this be done in Mercenaries?
I've changed these values in both Input.Map and Mouse.Map and I still don't have a proper mouselook.
Re: Inverted Mouse
Post by Sir MMPD Radick » Thu Dec 23, 2010 6:40 am
far as i know it should be, but i have never tried it in mercenaries to confirm that.
It may be inside of a different file for mercs. I am not sure
Jerad Gray
Re: Inverted Mouse
Post by Jerad Gray » Wed Feb 08, 2012 6:44 am
ellmo wrote:Can this be done in Mercenaries?
All you have to do is select down/up instead of up/down from the cycle list in the in-game control config.
Locked
