Difference between Battlepack and Titanium MW2
Collection of useful posts.
I will update this post as I find more information, because until now I was under the impression both were basically synonymous. It appears I was wrong.
Basically according to tyr, the versions are nearly the same, but Battlepack is only 8bit.
Tyr (alt.game.mechwarrior2)
Jun 10 2002, 10:26 am
The titanium versions are 16 with with
the option to install the 8 bit version instead. If you install the 8 bit
version of mw2 from titanium then you have just installed the battlepack
version.
(Update: Confirmed, it is compatible because it is the identical version that is compatible.)
I could use a confirmation on this next one, there were reports on usenet that the DOS version of netmech on the Battlepack is compatible with netmech dos.....
I highly doubt that it is true, but if anyone could confirm or deny this I would like to know. I will check on it in the mean time...
Lonewolf (alt.games.mechwarrior2)
Aug 8 1997, 12:00 am
DOS Netmech comes with the Battlepack but it is not the same as the
Battlepack Netmech.
