Joystick Trouble
ThePorthos
Joystick Trouble
Post by ThePorthos »
After about an hour of searching through the forums and a headache I figured I'd just ask this.
I'm loving re-living Mechwarrior via the MechVM. However, my current joystick (Logitech Extreme 3d Pro) seems to only have Y-X axis movement. Everyone knows a good mechwarrior needs to be able to twist his torso :D. So, what would one have to do to set this up for my z axis on the joystick? Thanks
ThePorthos
Re: Joystick Trouble
Nevermind I figured it out and now feel stupid.
Hadakajime
Post by Hadakajime »
post up your solution so other people can use it too. :)
ThePorthos
Its easy, just go into control options and go to custom configuration, I was hitting joystick control and it was kicking me to control panel. For anyone who has problems with the throttle being reversed, its as easy as clicking the -/+ next to the command binding and it will turn it into +/- (or vice versa)
