Pirate dropship never moves in SIG3 mission
thelonetaco
Post by thelonetaco »
I am playing the Mercenaries Titanium Trilogy edition, patched for XP. I am on the mission some walkthroughs have appreviated as SIG3 - I have just escaped from the Wolves, now I am trying to escape on a dropship with some pirates. The two objectives are to get to NavPoint Alpha and defend the dropship. After trying just about every combination of moves, including waiting around for 20 minutes, the pirate dropship just never moves.
Does anyone know if there is a fix for this problem? Is it even a known issue? I would settle for simply being able to continue with my game by skipping this mission, if that is a possibility. Trying to abort campaign pops up a message telling me I can't, and failing the mission gives me game over.
Any help would be greatly appreciated! Thanks
Re: Pirate dropship never moves in SIG3 mission
If you get stuck about the only way around it is to cheat.
ctrl + alt + shift and li will end your mission successfully.
thelonetaco
Thanks
Jerad Gray
Post by Jerad Gray »
OR if you have an older version of Mercs like me you have to use "likethecomstarbaby" as the cheat...
