Could use some help getting this running (resolved)
I've had my Mercs CD since probably 1998, its the red disc with no fancy stuff, DOS and Win95 compatible version 1.5. I've gotten the Win version to work before but it crashes far too much. Any way to get the DOS portion of it to work properly?
Re: Could use some help getting this running
You did give #2, but more info is still necessary.1. OS & Service Pack.
Actually, upon further tinkering, multiple reinstalls and yelling at my computer I got it to work through DOSBox, which it hadn't before. Imgmount is your friend, it seems
