Windows Vista
Windows Vista
Hi. I've recently gotten MW2 and MW2 Mercs again. Anyone have any ideas on how to make them work in Windows Vista? Thanks in advance, take care.
Re: Windows Vista
Just follow one of the tutorials here for the DOS version using DOSBOX and you will be up and running pretty easily.
If it is the 95 version there are ways to get that to work with the hook. DOS is better though. 95 versions are unstable.
Re: Windows Vista
Which version of MW2 do you have? If it's the DOS version, you will need DOSBox under Vista. MMPD might disagree, but I prefer installing the Windows version of MW2 under Vista become DosBox gives me bad framerates. Your Mercs disk may have both versions.
When I upload the next version of MechVM, you will have be able to choose which version of the game will be installed, so drop me a line if you want to install the Windows version. For installing the DOS version, simply setup DosBox and install using DosBox.
Re: Windows Vista
I have the ATI Rage edition of MW2 and the MSDOS/Windows 95 version of MW2 Mercs.
Re: Windows Vista
I believe in that case you are out of luck for MW2. Unless you have the origional hardware in the system (3d rage) there is no way to play. There are no wrappers currently for the 3d rage video card lineup.
Mercs though, yah you could go either the 95 way or DOS way. Your call.
Re: Windows Vista
Windows version has FAR better sound quality than DOS, but, then again, I've ran into less problems under DOS mode.
Re: Windows Vista
I would agree there. As I said though stability is the major issue.
Re: Windows Vista
Will MW2 and MW2 Mercs run in a Windows98 os?
Re: Windows Vista
The ATI Rage one will work on 98 for mech2 only if you have the origional hardware. If you do yes.
Mercs works on anything. Mech2 normally does as well, but you have a 'special' version which does not work.
You can play all of them directly on 98, but multiplayer will not work for you if you wished to join us for multiplayer; since Windows 98 is not capable of running dosbox properly.
My suggestion for mech2 is to go buy a normal version.. check the FAQ section for a list of good versions and ones which to avoid.
