How do INSTALL through DOSBOX?
Re: How do INSTALL through DOSBOX?
Post by Col.Kell » Fri Nov 14, 2008 10:49 am
Okay, Mercenaries is up and running! Thank you Radick and npsbre! The problem was I forgot that I also had to have the .IMG file, not just the .CUE. :oops:
Only problem here is that the game framerate is running a little slow, the screen is all choppy. I have looked at what the DOSBox help file had to say to fix this, I managed to improve this only a little, but not enough to be deemed "fixed". Do either of you have any suggestions on how to make the game framerate run smooth?
Post by Sir MMPD Radick » Fri Nov 14, 2008 2:19 pm
new computer... lol
Post by Col.Kell » Sat Nov 15, 2008 7:35 pm
Please don't discourage me Radick, I am annoyed by this enough as it is.
I am convinced that this is a DOSBox problem, because it never ran this way on the Windows hook or when I got it running on regular DOS after fumbling around on the distorted screen.
Post by Sir MMPD Radick » Sat Nov 15, 2008 8:13 pm
col Kell not trying to, but you are comparing apples and oranges the hook is completely different.
Mercs in DOSBOX is about 10x as laggy as without dosbox. DOSBOX = complete emulation. You are better off playing it with the hook in 95 or running mercs dos directly in XP without dosbox.
Mercs has much higher specs than that of mech2. I can bearly run it myself in dosbox.
Post by Col.Kell » Sun Nov 16, 2008 1:12 pm
hehe, I don't feel so bad now that I know it doesn't run well for people who have the cool new computers.
The whole purpose of me wanting to run Mercs under DOS was because I found it easier to test my mods "on-the-fly". But, I guess I don't need to be acting up like this, I should be glad it's working under the Hook program.
...And, I guess I should be glad that this is my 100th post! Yippee! :D
Post by Sir MMPD Radick » Sun Nov 16, 2008 1:25 pm
actually i have an old 2005 comp now...
Either way congrats on ya 100th :)
Post by Col.Kell » Sat Jan 31, 2009 8:38 am
New problem, I think this may be a combination of things but here it goes;
For Mercs under DOSBox, I have been using the same old .IMG file for the past 3 months or so.
One day out of the blue, I look to launch a mercnet mission alone so I could test some map mods.
Of course, everything appears to be running just fine, both the Mercs shell and Mercnet; the sound is playing, animations are running... Only problem is when I try to launch a mission, the game gives me an error message saying the CD is not inserted. :?
I am typing the same thing I normaly do:
IMGMOUNT D C:\MERCS\IMAGE.IMG -t iso (where D is my only disk drive)
then
MOUNT C C:\MERCS (where mercs is installed and the location of the game engine.)
then type
C:\
and lastly
MERCS (or mercnet).
I have removed the mercs gamejackal profile, just to make sure it doesn't interfere with anything. I don't know what the problem is. Any leads, tech crew? :)
Post by npsbre » Sat Jan 31, 2009 9:34 am
You should be mounting the cue file for DOSBox, not the img. The cue points to the img, so be sure not to rename the img after it's already been created.
Post by Col.Kell » Sun Feb 01, 2009 7:56 am
Wow am I feeling blonde :oops: thanks for that tho.
blackyoshi1230
Post by blackyoshi1230 » Wed Feb 04, 2009 4:48 pm
Sir MMPD Radick wrote: Mercs in DOSBOX is about 10x as laggy as without dosbox. DOSBOX = complete emulation. You are better off playing it with the hook in 95 or running mercs dos directly in XP without dosbox.
Mercs has much higher specs than that of mech2. I can barely run it myself in dosbox.
So that means I can play it straight up in WinXP through command prompt? Sweet.
I installed DOS through E: though, and E and F are my optical disc drives (you said something about requiring the lowest drive or D, but that's a restore hard drive), so that means I should put my disc in F: and hit Mercs.exe (not Mercswin.exe)?
I tried the Win95 version (successful install though), but after trying the hook (yeah, the target was mercswin), it gave me the blink-crash.
Using Mercs cross-platform v1.06 with WinXP SP2.
