Mercs DOS Music Cut Off
Havokq3
Post by Havokq3 » Thu Jan 26, 2017 3:45 pm
So, I am running Mechwarrior 2: Mercenaries version 1.06 in DOSBox, on Windows 7, and for whatever reason, the music tracks always cut off around a minute (except for the final mission music). If I insert the disc into the Disc Drive, and open it in Windows Media Player, all the tracks will be listed as lasting anywhere from 0:48 to 2:38(the latter is the final mission); but if I look up the tracks on Youtube, they will always play longer there. Why is this?
