Mercs 95 1.1 patch?
jcarroll53
Mercs 95 1.1 patch?
Post by jcarroll53 » Sun Jan 24, 2016 11:50 am
So i've been looking around for the 1.1 patch but all I've been able to find were broken links.. anyone know where I can find it?
Striker
Re: Mercs 95 1.1 patch?
Post by Striker » Mon Jan 25, 2016 3:23 pm
Sarna.net has a working patdch.
Can't get it to work properly on Windows 10 though, so if you have any lucks, be sure to let us know.
jcarroll53
Post by jcarroll53 » Fri Apr 22, 2016 9:28 pm
Well, I found a patch. I had to revert my main OS back to Windows 7. Windows 10/8/8.1 will not work because of the way that the Compatibility Mode is programmed (something about ACPI or something of the sort conflicting with the way it reads the game). Works flawlessly on Windows 7 64-bit.
