Odd Graphical Problem
hakiyah
Post by hakiyah »
Myself and a couple of friends having an odd issue with Mercs. I'm running the titanium version on MechVM, with Windows 7 64-bit, and everything is working perfectly, except for the debriefing screen. When a mission is finished, the game exits to the debriefing screen, then the graphics go all screwy and everything becomes illegible. As soon as the exit button is hit, it goes write back to the main dropship menu and everything is fine. Everything else works perfectly.
hakiyah
Re: Odd Graphical Problem
Post by hakiyah »
Nevermind, solved it myself. Going into the save/load menu, then returning to the debriefing screen fixes the mess. The same appears to hold true for any other color issues in menus.
