Missions don't run and auto fail
CateranEnforcer
Post by CateranEnforcer »
Okay, here's the setup:
Windows 7 64bit
DOS version of MW2:Mercs. I have long since lost my original CD so I am using DAEMON Tools to mount the CD image.
I run it in MechVM in DOSBOX.
Everything seems to work fine until I try to start a mission. In all 3 modes, whenever I try to start a mission, the screen goes black for a moment and then goes to the aftermath screen as a failure.
Any advice?
Re: Missions don't run and auto fail
hmm well not sure why that would be offhand but you should not be mounting the disc.
You need to have mechvm do that or i do not think it will work properly in DOSBOX.
So what you do is install the game with mechvm and point it to the .cue file. It should fix your issue I think.
CateranEnforcer
Just an update here:
I definately did not point it to the .cue file for my first attempts. Oops.
I created the .cue file with CloneCD and unmounted the CD from DaemonTools. In MechVM I tried to use "Install from CD Image" but it didn't ask for a file location. Upon running the game I encounter the same problem. Missions autocomplete and fail when run. I'll keep plugging away at it, there are some things on this forum I am still trying.
Ah actually install from disc. I do not think mechvm install from image does not work. I never had success with that method either.
Use the the install from disc then point it to the .cue file. Sorry for the confusion
Adamant
Post by Adamant »
I had the same problem as you but I've been playing Mercnet all week with my brother using the mech2.org server. I don't even use MechVM, instead I mount the .cue in dosbox using the imgmount command.
It works like a charm if you have the .bin and .cue named the same and mount the game directory first before mounting the cd.
example:
mount c c:\MERCSCD
c:
imgmount d c:\MERCENARIES_DOSWIN.cue -t iso
MERCS
in this case i'm going to the mercscd folder in c: where I have the game, then mounting the cd image i have in the c: (not in the mercscd folder) then running the game in the mercscd folder.
CateranEnforcer
I'll give that a try, though I haven't been able to find out much about .bin files. CloneCD created a .cue, .ccd, .sub, and the .img files. Where/how do I find it?
UPDATE EDIT: I placed all 4 of those files in the same location and ran the game via DosBox. So far I have the same issue with but slightly different. The game starts to show the green heartbeat loading bar, but stops shortly after giving me a "CD is not mounted" error.
when your making the disc you have to rip it with clonecd using the protected game disc option. it does apparently make a difference. That could be your issue.. only guess i have offhand
CateranEnforcer
No luck with that, I'm afraid.
I've been searching all night to figure how to read/convert that .bin file, so far with no success.
FreelancerMar
Post by FreelancerMar »
If you create the CD image using Clone cd, you will not need a Bin file. All you will need to do is have dosbox load/mount the *.cue file and all should be good. I have 2 different Mech installs. 1 through MechVM for more or less bug free play and 1 through Dosbox for tinkering with. I use cloneCD images for both.
I hope this helps out some.
catgamer109
Post by catgamer109 »
Well, I have the exact same problem. But in windows 98 on a retro system. First it was auto failing, then it was auto successing, and then it's auto failing again. Wtf is going on? (oops just noticed this was in mercs, I'm running 31cc)
