Adjusting screen for mechwarrior 2
- Demonslayer
ok just upgraded my pc to win 7 64bit and when i start my game the game screen is moved a bit to the to to the point were i cant select savegames,top menu,etc
running mechwarrior 2 mercs :platinum(titanium with bp graphics)
Re: Adjusting screen for mechwarrior 2
Are you using a resolution changer by chance? If you are then change the resolution to something else that your monitor supports.
- Demonslayer
nope using nothing
Try the resolution changer that kontza had made for mercs and it might work I am not sure.
File is in the zip on the page.
- Demonslayer
well i looked around the page but cant find resolution changer
It was on the bottom of the page.
Exe is called mechprep.exe
I will note though I am not sure it will work with titanium.... so i would try it but I have no real idea whether it will work...
- Demonslayer
it worked at first then reveted back to its regular self.. no luck yet
I need more information:
- What graphics hardware do you use?
- What is your graphics driver version?
- If you use Titanium graphics instead of battlepack, does that work?
- If you use MechVM shell, does that work?
- Can you take a screenshot?
- Demonslayer
Actually it runs perfect its just i need to fix the screen
intel(R)pentium(R) CPU g630 @ 2.70ghz
IDK
nope
no
dont have the software
IDK
nope
no
Try task-switching between the game and some other application.
