mercnet problems
Striker
Re: mercnet problems
Post by Striker » Fri Jan 22, 2016 11:11 am
Yes, under mercenaries patches.
You can also find the patches on sarna.net as well.
You will need to use DOSBOX probably to install it though. Place the patch in your Mercs install folder. Then use dosbox to navigate to that folder and run the patch from there.
Trigger
Post by Trigger » Fri Jan 22, 2016 9:47 pm
Awesome, ill try that. Thanks mate
Trigger
Post by Trigger » Fri Jan 22, 2016 10:02 pm
Patching it didnt work. Seems like my only option is finding a way for a connection type to come up in mercs battlepack
Striker
Post by Striker » Sat Jan 23, 2016 10:01 am
What happens when you try and patch it?
Trigger
Post by Trigger » Sun Jan 24, 2016 1:22 am
it updates all the files for 1.05 then again for 1.06, then i try to load game again and unable to find cd.
Striker
Post by Striker » Mon Jan 25, 2016 3:31 pm
Hmm interesting.
Ok, well if it helps here is how I normally install my Merc game:
1) Get MechVM on this site and extract the contents into a folder somewhere on your c:\ drive
2) Create a bin/cue image of your CD (not sure if .iso or other images work, but that is what I do). Put the image into your MechVM folder
3) Use a virtual CD drive like Virtual Clone Drive to mount that image (you do not need the cd in your drive at this point)
4) Run MechVM and goto install+import at the top. Press the associated install button just under the bar at the top. It will ask you for your CD Image, so point it to the image you created in the MechVM folder
5) Put the 1.05 patch in your MechVM\Games\mw2-merx folder
6) Use dosbox, go into that folder and run the 1.05 patch. Make sure not to install it using the default directory but the directory where Mercs is actually installed in (that mw2-merx folder)
7) Run the projpat file afterwards.
8) Install the 1.06 patch (no need to run projpat after the above step)
9) Run the game from MechVM. Goto play game, and select the DOS version of Mercs
Trigger
Post by Trigger » Mon Jan 25, 2016 10:48 pm
Followed your instructions to the letter, still got the dreaded message insert the mercenaries cd :(
Before the game actually loads to the callsign and connection screen, I see in the dosbox window c mounted as ../games or whatever and D imgmounted as the image so thats all good and the tunnelling works. I try to host a game and it wants to know where the cd is XD I was actually excited coz i havent been able to get mechvm to install dosbox before thought it might do the trick
Striker
Post by Striker » Tue Jan 26, 2016 11:20 pm
Yeah it is strange that it thinks it needs the cd. Is this problem just Mercnet, or do you experience it with the main game too?
Trigger
Post by Trigger » Wed Jan 27, 2016 3:34 am
Yea the game too, if i try to go straight into mercs it wont find the cd, and cant host in mercnet.
Thanks for being patient I've been bustin to play this for a long time ever since i was a kid really so im gonna keep trying till something good happens. Appreciate the help!
