A curious question
GaussNova
A curious question
Post by GaussNova »
Hi, my name is GaussNova, which, if you are wondering what that is, is a Supernova with 6/5 Gauss Rifles on it, and I need your help, so listen up. I am planning to grab a vintage Gateway 2000, that I believe comes with Windows 98/Windows 98 SE. What operating system is good to run MechWarrior 2: Battlepack? MechVM on my newer PC is sometimes odd and glitches up oftenly, though MechVM is a very nice program. Besides, it doesn't feel right, playing on a newer system, as the feeling of playing MechWarrior 3. So I hope you send some recommendations on what OS I should run it on. Thanks for helping! :D
Re: A curious question
Heya welcome!
Well, usually a 300 or 500mhz Pentium 3 will do fine with a Voodoo 5 5500 AGP.
OS Windows 98 SE works the best for all the versions of the game.
Hope that helps
GaussNova
Post by GaussNova »
Thank you! I'll look at the 2000's specs, and see if there is a way to upgrade to a VooDoo 5*, which may be risky, due to it being an older PC (1997) :shock: But if I get the thing and it runs Mech2 and Mech3 "for giggles", ill notify you ASAP! :D
GaussNova
Post by GaussNova »
By the way, if you want to see the specs of this Gateway, here they are.
Introduction: 1997
Processor : Intel Pentium II
Frequency : 266 MHz
RAM : 32Mo (256 Mo Max.)
Stockage : HDD 4 Go, CD-ROM 24x
Video Card: NVidia STB Velocity 128 video AGP,
Modem : 56k
Not sure if this will run Mech2 or Mech3 good... o_O
should run mech2 fine. mech2 was made for the generation prior to pentium.. 90mhz... least that was the original. 233 mhz should run battlepack semi decent its on edge
