Netmech Server - Address Change
If you are using the netmech build in our download section go into the directory and open the netmch.conf file and go to the bottom.
If you are using IPXNET CONNECT dosbox.game-server.cc 10000
Replace it with IPXNET CONNECT mech2.org 10001
dosbox.game-server.cc is just a pointer and it does not appear to be pointing to our address anymore. I have no control over it.
Re: Netmech Server - Address Change
also if the config files asks you what program to open it with (mine did) open it with notepad
Uploaded a fixed version that replaces the dosbox.cc hostname with mech2.org.
This thread is no longer required [Please delete]
- Clan 2nd MechWarrior
The thread is still valid for all players who have not updated, so I think we can let some time pass before we unsticky it.
Download MechVM
Re: Netmech Server - Address/PORT Change
PORT change
10001 is the new port.
I did this and there's no change to NetmechDos... Well as far as I can tell.
you changed in netmch.conf in the netmechdos folder the address at the bottom to make the IPX connect to mech2.org 10001?
Well, I just did a drop testwith madsonovich, and the lobby works... you might wanna come on IRC and ask for a game or something it is not likely that you will find a game if you don't come on IRC.
Edit: Sounds like you already did fix it and played madsonovich this morning.
