Hidden Mechs
Demonslayer
Hidden Mechs
Post by Demonslayer »
when i use the unlock codes for the hidden mechs the game crashes in the mechlab while trying to look for them
Re: Hidden Mechs
You posted this under MechVM-2010-06-15, but the current version is MechVM-2011-04-04.
In order to answer your query, I'll need more information. Which version of MW2 are you talking about, and which codes are you trying to use? Which method do you use to run the MechLab?
Demonslayer
Re: Hidden Mechs
titanium edition mw31stcc/mechVM 2011-04-04/windows7ultimate/32bit/AMD graphics ATIraedeon 4200/Enzo,Hobbes,Calvin. and the method is just regular win7 no compatiblity used
Re: Hidden Mechs
MW2:31stcc use different cheat codes in the DOS and Titanium Trilogy versions:
http://www.cheatscodesguides.com/pc-che ... warrior-2/
http://www.cheatscodesguides.com/pc-che ... m-trilogy/
So the DOS codes are not likely to make any difference. There may be a way to use the hidden mechs using MechVM shell. I'll look into it. While the DOS game does not allow you to configure the hidden mechs, with MechVM you can.
Demonslayer
Re: Hidden Mechs
the codes are the same but still wont work
