Mercenaries: Dropship
MechWarrior 2 Related Downloads go here.
I have no idea if this works or not, but I am posting it anyway for the Mercs fans in the audience.
Be sure to back up your mercs before even trying this.
Basically this program supposedly allows you to pilot dropships, and vehicles from its description.
You may download it here.
Jerad Gray
Re: Mercenaries: Dropship
Post by Jerad Gray »
I will give this one a test.
harpuia101
Post by harpuia101 »
I can confirm that it works. Does NOT work on the titanium edition of the game, since it requires that the DOS version be present. Running the executable brings up a DOS window with 3 lists: Missions, Variants(I believe), and Chassis. Certain combinations will cause the program to crash. Once you select the mission and chassis, it will immediately launch up the game to that mission with you using that chassis (including dropships,tanks,aerofighters and all that).
Clan 2nd MechWarrior
Thanks for the testing and report.
BAH!!,,,,if we could just use them in netmech:P
You know, there is a way to do this without this application.
On DOSBox, after you have mounted your Mercs directory, type in at the command prompt: "mw2 sol1scn1" to play the first Solaris VII level or "mw2 gra2scn1" to play the second Gravanhage level, etc.
I haven't found out how to choose what mech\aircraft\vehicle you may want, but you must always have the file "userstar.bwd" in your Mercs directory.
This can also work with MW2:31cc or GBL.
Vahn
Post by Vahn »
Wow, this is the BEST addon ever lol! pewpew with a dropship!
Hey Vahn, do you have MW2:31stCC too? If you like the mercs dropship mod, you can play as every vehicle, mech (new mechs too), and aircraft in 31stCC using KAM.
