For those looking for the Battlepack 1.05 patch you may download it here.
MechWarrior 2 Battlepack Patch 1.05
MechWarrior 2 - Battlepack 1.05 Patch
Re: MechWarrior 2 - Battlepack 1.05 Patch
It is a MechWarrior 2 bundle.. similar to titanium.
I am running Vista + MechVM with Battlepack.
I downloaded the patch but it says MW2 not found (because the installation is not in program files.) Any idea on what files I need?
I think I might copy the programs to the Program Files folder and patch it, and copy those changed files back to the MechVM directory, but I can't remember what the original directory structure was!
Any other ideas?
Any other ideas?
I believe that if you just run the extractor and put the files in a place you can find them you can just look for the MW2 folder it creates then go and overwrite the files in that folder with the ones in the Battlepack folder.
However if you are looking for a fix for the small window of Battlepack in Vista or Win 7 there is no way to fix this. You need XP or below to get it working properly.
