BattleTech CHESS VOTE: ROOK
What Mechs do you want as the Inner Sphere and Clan ROOKS?!
You may select up to 2 options
View results
Keebler
Post by Keebler » Mon Aug 16, 2010 9:00 pm
EDIT: DUE TO THE OVERWHELMING AMOUNT OF EMAILS ABOUT THE REQUEST FOR THE CATAPULT. I HAVE ADDED IT TO THE VOTE OPTIONS. YOU CAN CHANGE YOUR VOTE IF YOU WANT AFTER LOGIN.
THANK YOU...
Please Vote for your choice of ROOK. This list is all the comparable mechs with weight chassis.
Please keep in mind when making your choices in Weights. While not exactly a determining factor, a 15 Ton difference could make a very considerable advantage, and would leave the opponents looking unbalanced.
Also note; Be sure to vote for ONE Inner Sphere and ONE Clan ONLY! Please, do not vote for two Inner Sphere.
This is IS vs Clan. Most of the mechs were chosen because of their Weight and Armament, and their inclusion in the 2750/3025/3050/3058
